Ana içeriğe geç
Fitbit Surge GPS Replacement
Neye ihtiyacın var
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: adım 1, 2 resimden 1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: adım 1, 2 resimden 2.
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: adım 2, 3 resimden 1. Fitbit Surge GPS Replacement: adım 2, 3 resimden 2. Fitbit Surge GPS Replacement: adım 2, 3 resimden 3.
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: adım 3, 2 resimden 1. Fitbit Surge GPS Replacement: adım 3, 2 resimden 2.
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: adım 4, 2 resimden 1. Fitbit Surge GPS Replacement: adım 4, 2 resimden 2.
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
Sonuç
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 farklı kişi bu kılavuzu tamamladı.
Angela Pitts
1.187 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G3
3 Üyeler
Bir Yorum
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 2,991
