Ana içeriğe geç
Fitbit Surge Touchscreen Sensor Replacement
Neye ihtiyacın var
  1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: adım 1, 2 resimden 1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: adım 1, 2 resimden 2.
    • Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Touchscreen Sensor Replacement: adım 2, 3 resimden 1. Fitbit Surge Touchscreen Sensor Replacement: adım 2, 3 resimden 2. Fitbit Surge Touchscreen Sensor Replacement: adım 2, 3 resimden 3.
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge Touchscreen Sensor Replacement: adım 3, 2 resimden 1. Fitbit Surge Touchscreen Sensor Replacement: adım 3, 2 resimden 2.
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Touchscreen Sensor Replacement: adım 4, 1 resimden 1.
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Touchscreen Sensor Replacement: adım 5, 2 resimden 1. Fitbit Surge Touchscreen Sensor Replacement: adım 5, 2 resimden 2.
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Touchscreen Sensor Replacement: adım 6, 1 resimden 1.
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
  7. Fitbit Surge Touchscreen Sensor Replacement: adım 7, 1 resimden 1.
    • Remove the touchscreen sensor using a spudger or your fingers.
    • Note: In this photo we removed the metal cover on the main PCB, but you do not need to remove it for this guide.
Sonuç
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
7 farklı kişi bu kılavuzu tamamladı.
Angela Pitts
1.187 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G3
3 Üyeler
5Kılavuz Yorumları
Is there a company that will perform this fix for me?
Terry Brown - Yanıt
Where can I get a replacement sensor?
Francisco Cortez - Yanıt
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Erazm Gondoresku - Yanıt
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras -
Is anyway I can buy the bus
Ajay Kumar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,854
