Ana içeriğe geç
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Neye ihtiyacın var
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 1, 3 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 1, 3 resimden 2. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 1, 3 resimden 3.
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 2, 3 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 2, 3 resimden 2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 2, 3 resimden 3.
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 3, 3 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 3, 3 resimden 2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 3, 3 resimden 3.
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 4, 1 resimden 1.
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 5, 3 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 5, 3 resimden 2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 5, 3 resimden 3.
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 6, 2 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 6, 2 resimden 2.
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 7, 2 resimden 1. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 7, 2 resimden 2.
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: adım 8, 1 resimden 1.
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emmanuel Emedeke
184 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 5,113
