Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Flat-screen TVs are often secured to the wall using wall mounts. If your wall mount (Mounting Dream MD2462) is coming out of the wall, you can use this guide to repair it. Loose screws can potentially cause the TV to fall out of the wall, creating a safety hazard. Be sure to unplug the cables in your TV before beginning this repair.
It is also essential to note that this product contains small items which may be choking hazards for children. Before beginning this guide, make sure that all the parts are in good condition. The product also includes some extra hardware components, which might not be needed.
Neye ihtiyacın var
Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
