Ana içeriğe geç
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: adım 1, 1 resimden 1.
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: adım 2, 2 resimden 1. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: adım 2, 2 resimden 2.
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Somnic
195 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 58
Her zaman: 1,033
