Ana içeriğe geç
Fixed Gear Bike Chainring Replacement
Neye ihtiyacın var
  1. Fixed Gear Bike Chainring Replacement, Chainring: adım 1, 2 resimden 1. Fixed Gear Bike Chainring Replacement, Chainring: adım 1, 2 resimden 2.
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: adım 2, 2 resimden 1. Fixed Gear Bike Chainring Replacement: adım 2, 2 resimden 2.
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: adım 3, 2 resimden 1. Fixed Gear Bike Chainring Replacement: adım 3, 2 resimden 2.
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: adım 4, 1 resimden 1.
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: adım 5, 1 resimden 1.
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Bitiş Çizgisi
aljndro__
121 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 üyesi
CSULA-BRIGGS-F23S1G1
6 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 131
