Ana içeriğe geç
Fixing Pop up Flash Receptacle
Neye ihtiyacın var
  1. Fixing Pop up Flash Receptacle, Battery: adım 1, 1 resimden 1.
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
    FixBot'a Sor
  2. Fixing Pop up Flash Receptacle: adım 2, 1 resimden 1.
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
    FixBot'a Sor
  3. Fixing Pop up Flash Receptacle: adım 3, 1 resimden 1.
    • Remove the battery from inside the battery housing and set the cover aside.
    FixBot'a Sor
  4. Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: adım 4, 2 resimden 1. Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: adım 4, 2 resimden 2.
    • The inside of the flash shoe has a removable cover which is just snapped in place.
    • Using the flathead screwdriver, pry up on the front end of the cover.
    • Warning: The cover is on tight and is tough to pry off.
    FixBot'a Sor
  5. Fixing Pop up Flash Receptacle: adım 5, 1 resimden 1.
    • Loosen, but do not remove, the 4 screws on top of the flash shoe.
    FixBot'a Sor
  6. Fixing Pop up Flash Receptacle: adım 6, 1 resimden 1.
    • Locate the black pludger sticking up out of the flash shoe.
    • The black pludger may not be visible, which is why the flash is broken. Just locate the hole to where it should be and move on to the next step.
    FixBot'a Sor
  7. Fixing Pop up Flash Receptacle: adım 7, 1 resimden 1.
    • If you can remove the bracket from the camera to reset the hotshoe, this is preferable to using a paperclip to reset the sensors.
    • Push a paperclip in and out of the plunger hole, ensuring the plunger moves up and down freely.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mark
197 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G9
4 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
What about the other way, where the external flash IS installed (and the camera is successfully communicating TTL focal length data to it) yet the camera still doesn’t believe there is an external flash installed? Sometimes twisting the external flash a little causes the camera to change its mind and then it works, but then it usually forgets by the next exposure.
Think this mechanism could be causing that behavior too?
Andrew - Yanıt Paylaş
Take the hotshoe off, and make sure they move freely. Once they're moving freely, reverse disassembly and make sure it works. This will ensure it is properly "reset".
Nick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 94
Her zaman: 5,155
