Ana içeriğe geç
Giriş
Although the Roccat Kone[+] represents Roccat's top of the line model in gaming mice category, it has one small weakness within the scroll wheel mechanism. It is very sensite to dust...and after some time it will start to malfunction
In this video you will find a short review of the Kone[+] and the manifestation of the glitch.
Before you atempt to perform this repair make sure the glicth is actually permanent, and make an attempt at fixing it with a few blows with an air compressor.
  1. Unplug mouse.
    • Unplug mouse.
    • Cover the optical sensor with tape
  2. With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse. Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
    • With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse.
    • Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
    • Once glidez are removed, screws are in plain sight
    • DO NOT TOUCH OR STAIN THE STICKY PART OF THE GLIDEZ, otherwise they will not stick back.
  3. Unscrew all 4 screws. Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
    • Unscrew all 4 screws.
    • Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
    • Lower and upper part are attached by 5 wires
    • You can either leave them attached or unplug the wires using the tweezers
    • I prefered to separate the two parts for better handling of the lower part, where optical sensor and scroll sensor are located.
  4. Replug the mouse in its initial USB port. Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges
    • Replug the mouse in its initial USB port.
    • Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges
  5. Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying. plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
    • Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying.
    • plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
    • If this won't fix it, this probably means the scroll sensor is permanently damaged/defective. (RMA?)
    Actually you have to apply the contact cleaner into the plastic box where are those contractors. The arrow points wrong . It point where is the simple mechanism responsible for scrolling tension. The "click" sound when you scroll .
    Bottom line , very big THANK YOU for the guide. Just repaired my friends Kone+ in 10 minutes.
    szwedu - Yanıt
    Used this to fix my R.A.T 7 scroll problem and it worked like a charm!
    Many thanks.
    MK - Yanıt
    Worked like a charm on my MMO7. Thank you 100x; I already thought that I will have to buy new mouse..... :)
    Robert Topolovec - Yanıt
    Or don’t ignore WD-40 if you already have WD-40 electric contact cleaner ;)
    Enio Fernandes - Yanıt
  6. If the mouse wheel is not sturdy enough for your taste you can easily insert small pices of cropped paper between spaces around the mouse wheel I used small piece of folded sticky note I always keep on my desk. :) No more wiggling mouse wheel.
    • If the mouse wheel is not sturdy enough for your taste you can easily insert small pices of cropped paper between spaces around the mouse wheel
    • I used small piece of folded sticky note I always keep on my desk. :) No more wiggling mouse wheel.
  7. Once the glicth is fixed re-attach the wires and reassemble the lower and upper part together.
    • Once the glicth is fixed re-attach the wires and reassemble the lower and upper part together.
    • When reattaching the glidez use same method backwards. Basically apply pressure on the the heated glidez and they should stick back to their place.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Isip V Nicola
443 İtibar
1 Kılavuz yazıldı
15 Yorum
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Michael Ungers - Yanıt
Thanks for the suggestion, already corrected. :)
Isip V Nicola - Yanıt
Worked perfect with hair dryer and WD-40 in 15 minutes!
rinaf - Yanıt
Excellent concise guide. Thank You!!!
brenogrady - Yanıt
Thanks so much, it worked perfectly on a Roccat Savu. The side buttons were not working anymore after a mouse drop.
Just be patient with the glides & the hair drier.
John Doe - Yanıt
i did it and it works perfectly now!
Alexander Domino - Yanıt
I am really happy, that i've found that post. PERFECT! Thanks Autor and a man, who pointed out a mistake in Step 5. You should put wd-40, where the green arrow points (not on gear but in a little hole between constant and moving pieces).
soulhunter97 - Yanıt
I just did it and worked, even if sometimes (really rarely) i scroll one unit and it goes in the other way or doesn't do anything. Hope it will last.
I didn't use the wd40 contact cleaner, but the svitol silikon spray (technik).
In my case, the scroll sensor was all wet (it was something like oil) and the metal circle had (still has) circle stripes, so I just cleaned everything making it all dry, then I added just a bit of svitol
I also added a piece of paper (like in the guide, in front of the scroll wheel) on the left side of scroll sensor, where the metal piece is (the one that makes "tac" when you use the wheel), so it makes more pressure and you won't do an opposite scroll for error (the sensor is very sensible)
Mario - Yanıt
Hey guys, I can see all of these successful stories and my roccat kova + mmb has been a bit faulty and doesn't always register when I scroll. (weapon changes for ex.) Is there any danger in this method? I have already taken the cover off but im a bit wary of flooding the mouse and im a bit confused where i should put the wd-40 as there is a comment saying to put it some where different so could someone please help me out?
Thanks
Jacob Maschler - Yanıt
just repaired my Kone[+]Plus after it fell down and the scroll wheel was running free; the axis of the wheel had slipped out of the gearbox. just had to put it all in place again, and removed some wrapped up dog and cat hair on that occasion ;)
was surprised to see it has an extra metal cased switch for the left mouse button, in addition to the micro switch ... chose to buy it because it had not only the most precise wheel mechanics but also the best mechanical clicking sound of all mice i tested in the shop ... now i know why!
thanks for the excellent instructions how to open up this beast!
capsuleerpogostemoncablin - Yanıt
Hi, what is the name of the component that you point in the picture numer 5 (which it says we have to put wd-40 spray), couse I have a genius bt 905t Bluetooth mouse but this part is broken completely, and i dont know how to ask for it, in a electronic store.
Thanks in advance
Gustavo - Yanıt
works like a charm! You just saved me a whole new mouse!
Thor - Yanıt
Thanks for the guide! It gave me the confidence to pull apart my KAIN 120 AMIO to fix the same issue. It wasn’t quite the same process and removing the wheel assembly had me stumped for a minute, so I shot pictures and made a guide for that model based on your guide.
Roccat Kain 120 Amio Scroll Wheel Disassembly
Thanks again. :)
Craig Haydock - Yanıt
Thanks so much, it worked perfectly for my Kone AIMO Remastered! (I used a hair dryer)
f hu - Yanıt
Thank you so much! Worked like a charm on my Kone Pure Optical
Pascal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 74
Son 30 gün: 387
Her zaman: 46,558
