Ana içeriğe geç
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
Neye ihtiyacın var
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: adım 1, 1 resimden 1.
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: adım 4, 1 resimden 1.
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: adım 5, 1 resimden 1.
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: adım 6, 1 resimden 1.
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nicholas Roppolo
384 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 56
Her zaman: 1,364
