Giriş
The model of this particular faucet is unknown, though I believe it is a Kingston brass given the handle design. If you need to find out the model of your faucet, you can check the handles for the brand tag/logo, or the stem canister of the handle. To check the stem canister, you may have to remove the faucet base. You should be able to find instructions with a quick Google search, as this is not covered in this guide.
This guide shows the user how to fix a leaky faucet neck by replacing the O-ring found between the faucet neck and faucet base. This O-ring acts as a seal to prevent leakage while the faucet is turned on. The O-ring can be found at your home improvement store and is a fairly common item. An important note worth mentioning is that by taking your faucet neck into one of these home improvement stores, you can find help determining what size O-ring you will need.
Here is an article on how to find your faucet model brand.
Neye ihtiyacın var
Rotate both the hot and cold water valves underneath the sink in order to turn them off.
Test that the water is turned off by turning the faucet on for both cold and hot water and checking if any water runs. If there is still running water, you either turned the wrong valve(s), or you need to turn them the other direction.
2 farklı kişi bu kılavuzu tamamladı.
