Giriş
If your refrigerator door is constantly popping open due to a weak seal, then this guide is the perfect place to look. Many people assume that if the door seal is not working, then either the whole door or the entire refrigerator has to be replaced. In reality, its possible that only the seal needs to be replaced, but most of the time simply washing and realigning the seal is enough to fix it. This guide shows a simple way to clean your current refrigerator door seal and reattach it to your door.
Neye ihtiyacın var
Grab a Phillips Head Screw Driver
Lift up the door seal and locate the screws underneath that hold the seal in place. Loosen the screws to where they are pretty loose, but not out of their hole.
Your refrigerator should now stay shut properly, and the seal should be tightly secured in place. To assure proper functionality, check every once in awhile to make sure the seal is firmly in place.
59 farklı kişi bu kılavuzu tamamladı.
11 Yorum
Love that you show how to fix on a mini fridge! #CollegeLife Thanks for this :)
How can I fix the seals on chest fridge.
How much should the GE repairman charge for this repair? My mother-in-law was told it’ll cost her between $250-$275. I think that’s too much due to the cost of the seal. Does the labor cost account for the extra $200?
CLICK on the link here to help us engineering students to solve Fridge door problems!! https://docs.google.com/forms/d/e/1FAIpQ...
DON'T PUT VASELINE. I've ruined 2 fridges with this, now they're constantly running. You'll need silicon grease. This article is right. If it ain't broke, don't fix it, and &&^& the Vaseline guys
The seal was indeed damaged, but the door is unbalanced. Next repair for my 30 year old fridge.
Thanks for the great guidance.
Buy used support the little guy who refurbish
Thanku so much. It was really helpful. Got my problem fixed by ur advice.
How to fix a fridge or freezer seal: The easy way!
Use Duct tape to hold the door closed while you push (gently crushing the door seal) the door closed as hard as you can easily do. Leave the duct tape on for about 24 hours.
In most cases this will cause the door seal to re-level itself and seal better for a long time to come.
Generally, if a dollar bill placed between the door and the fridge comes out EASILY it means that that spot is not sealing well.
