Ana içeriğe geç
Fixing a Small Animal Cage Ladder
Neye ihtiyacın var
  1. Fixing a Small Animal Cage Ladder, Replacing the Rope for a Small Animal Cage Ladder: adım 1, 1 resimden 1.
    • Take your ladder out of the pet’s cage and lay it out to clearly assess the damage.
  2. Fixing a Small Animal Cage Ladder: adım 2, 3 resimden 1. Fixing a Small Animal Cage Ladder: adım 2, 3 resimden 2. Fixing a Small Animal Cage Ladder: adım 2, 3 resimden 3.
    • Gather your supplies for the fix (ie: new rope, scissors, ruler, sewing kit, clips). These items will be used to fix the small ladder.
  3. Fixing a Small Animal Cage Ladder: adım 3, 2 resimden 1. Fixing a Small Animal Cage Ladder: adım 3, 2 resimden 2.
    • Cut the old rope in the ladder with scissors and pull it out of the cylindrical wood pieces.
    • Make sure the knots at the ends of the rope are cut. This will enable you to pull the rope out easily.
  4. Fixing a Small Animal Cage Ladder: adım 4, 1 resimden 1.
    • Measure your new rope to the length of the ladder using a ruler.
  5. Fixing a Small Animal Cage Ladder: adım 5, 1 resimden 1.
    • Begin pushing rope through the individual holes in the wood pieces (use a sewing kit if necessary).
    • If there is the need to use a sewing kit to drag the rope through the wood here is how to do so: Push the needle through the end of the rope and tie a knot around the rope. Once you are finished with this, push the needle through the rope holes and then sew the rope through the individual pieces.
  6. Fixing a Small Animal Cage Ladder: adım 6, 1 resimden 1.
    • Once all the rope has connected the wood into a ladder, tie knots at each end to keep the pieces together.
  7. Fixing a Small Animal Cage Ladder: adım 7, 1 resimden 1.
    • Add clips to the ends of the rope and attach to the small animal cage.
    • If the clips cannot attach to the rope, tie the rope around the clips.
Sonuç
Katrina Hartmann
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 323
