Ana içeriğe geç
Fixing the Error Code 165-6596
Neye ihtiyacın var
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: adım 1, 2 resimden 1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: adım 1, 2 resimden 2.
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: adım 2, 1 resimden 1.
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: adım 3, 1 resimden 1.
    • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: adım 4, 1 resimden 1.
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
Sonuç
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
2 farklı kişi bu kılavuzu tamamladı.
ChrisLord9
307 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 66
Her zaman: 2,931
