Ana içeriğe geç
Flash Motherboard
Neye ihtiyacın var
  1. Flash Motherboard, Front and Back Covers: adım 1, 3 resimden 1. Flash Motherboard, Front and Back Covers: adım 1, 3 resimden 2. Flash Motherboard, Front and Back Covers: adım 1, 3 resimden 3.
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    FixBot'a Sor
    Yorum Ekle
  2. Flash Motherboard: adım 2, 1 resimden 1.
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    FixBot'a Sor
    Yorum Ekle
  3. Flash Motherboard: adım 3, 1 resimden 1.
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Flash Motherboard: adım 4, 2 resimden 1. Flash Motherboard: adım 4, 2 resimden 2.
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  5. Flash Motherboard: adım 5, 1 resimden 1.
    • The camera should look like this once the front cover is removed.
    FixBot'a Sor
    Yorum Ekle
  6. Flash Motherboard: adım 6, 3 resimden 1. Flash Motherboard: adım 6, 3 resimden 2. Flash Motherboard: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Flash Motherboard: adım 7, 1 resimden 1.
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    FixBot'a Sor
    Yorum Ekle
  8. Flash Motherboard, Flash Motherboard: adım 8, 1 resimden 1.
    • Turn to the front of the camera.
    • Find the flash motherboard located behind the flash assembly on the top right.
    FixBot'a Sor
    Yorum Ekle
  9. Flash Motherboard: adım 9, 1 resimden 1.
    • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
    • Once the cables are disconnected, you are now ready to install a new motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jakub
134 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G6
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 40
Her zaman: 4,480
