Ana içeriğe geç
Flashforge Finder 2 Fan Cleaning or Replacement
Neye ihtiyacın var
  1. Flashforge Finder 2 Fan Cleaning or Replacement, Work safely: adım 1, 1 resimden 1.
    • Shut down the back switch and disconnect the printer power supply
    • If used recently wait for the extruder to cool down
  2. Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: adım 2, 3 resimden 1. Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: adım 2, 3 resimden 2. Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: adım 2, 3 resimden 3.
    • Remove the three screws on the extruder top with a 2.5 Allen key or an appropriate screwdriver bit
    • Gently lift up the extruder cover
    • Pay attention to the flat cable while lifting the cover
  3. Flashforge Finder 2 Fan Cleaning or Replacement, Disconnect the fan: adım 3, 1 resimden 1.
    • Using a spudger, disconnect the fan connector
    • Route the cable to free it
  4. Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: adım 4, 2 resimden 1. Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: adım 4, 2 resimden 2.
    • Remove the two Phillips screw holding the fan
  5. Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: adım 5, 2 resimden 1. Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: adım 5, 2 resimden 2.
    • The fan can now be removed from the extruder. If you need to replace it, just follow the steps in reverse order with the new fan
    • If you are cleaning the fan, release the three clips holding it together with a spudger
  6. Flashforge Finder 2 Fan Cleaning or Replacement, Clean the fan: adım 6, 1 resimden 1.
    • Using compressed air and a brush, clean the fan from dust and debris
Sonuç
dinoo_fixit
1.386 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 81
