Ana içeriğe geç
Flip Ultra HD USB Latch Spring Replacement
Neye ihtiyacın var
  1. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 1. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 2. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 3.
    • Here is the Flip Ultra HD and it shows lots of use.
    • The USB latch does not return to the upright position when the USB arm is retracted.
    • Slide the battery latch to unlock
  2. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 1. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 2. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 3.
    • Slide the front panel down and up to remove.
    • Remove the battery by pulling up on the tab
    • Peel the identification sticker back about half way.
  3. Flip Ultra HD USB Latch Spring Replacement: adım 3, 2 resimden 1. Flip Ultra HD USB Latch Spring Replacement: adım 3, 2 resimden 2.
    • Beneath the sticker is a rectangular opening that houses the spring for the USB latch return. In this case it is clearly broken
    • Use a pair of Needle Nose Pliers to remove and replace the spring
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
784.298 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
560 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 911
