Ana içeriğe geç
Flip Ultra HD USB Latch Spring Replacement
Neye ihtiyacın var
  1. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 1. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 2. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: adım 1, 3 resimden 3.
    • Here is the Flip Ultra HD and it shows lots of use.
    • The USB latch does not return to the upright position when the USB arm is retracted.
    • Slide the battery latch to unlock
    FixBot'a Sor
    Yorum Ekle
  2. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 1. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 2. Flip Ultra HD USB Latch Spring Replacement: adım 2, 3 resimden 3.
    • Slide the front panel down and up to remove.
    • Remove the battery by pulling up on the tab
    • Peel the identification sticker back about half way.
    FixBot'a Sor
    Yorum Ekle
  3. Flip Ultra HD USB Latch Spring Replacement: adım 3, 2 resimden 1. Flip Ultra HD USB Latch Spring Replacement: adım 3, 2 resimden 2.
    • Beneath the sticker is a rectangular opening that houses the spring for the USB latch return. In this case it is clearly broken
    • Use a pair of Needle Nose Pliers to remove and replace the spring
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
856.326 İtibar
123 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 1,306
