Ana içeriğe geç
Flip Video Directional button replacement or cleaning
Neye ihtiyacın var
  1. Flip Video Directional button replacement or cleaning, Outer Shell: adım 1, 2 resimden 1. Flip Video Directional button replacement or cleaning, Outer Shell: adım 1, 2 resimden 2.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Directional button replacement or cleaning: adım 2, 1 resimden 1.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Directional button replacement or cleaning: adım 3, 2 resimden 1. Flip Video Directional button replacement or cleaning: adım 3, 2 resimden 2.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Directional button replacement or cleaning: adım 4, 1 resimden 1.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Directional button replacement or cleaning: adım 5, 1 resimden 1.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: adım 6, 1 resimden 1.
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
100 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G21
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,953
