Ana içeriğe geç
Flip Video Lens Replacement
Neye ihtiyacın var
  1. Flip Video Lens Replacement, Outer Shell: adım 1, 2 resimden 1. Flip Video Lens Replacement, Outer Shell: adım 1, 2 resimden 2.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Lens Replacement: adım 2, 1 resimden 1.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Lens Replacement: adım 3, 2 resimden 1. Flip Video Lens Replacement: adım 3, 2 resimden 2.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Lens Replacement: adım 4, 1 resimden 1.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Lens Replacement: adım 5, 1 resimden 1.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Lens Replacement, Circuit Board: adım 6, 1 resimden 1.
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Flip Video Lens Replacement: adım 7, 1 resimden 1.
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Flip Video Lens Replacement: adım 8, 1 resimden 1.
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Flip Video Lens Replacement: adım 9, 1 resimden 1.
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
  10. Flip Video Lens Replacement, LCD Screen: adım 10, 1 resimden 1.
    • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
  11. Flip Video Lens Replacement: adım 11, 1 resimden 1.
    • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
  12. Flip Video Lens Replacement: adım 12, 1 resimden 1.
    • Gently pull out ribbon cable.
    • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
    • The LCD screen is now removed and can be replaced.
  13. Flip Video Lens Replacement, Lens: adım 13, 2 resimden 1. Flip Video Lens Replacement, Lens: adım 13, 2 resimden 2.
    • Flip over circuit board so the ribbon connector is facing up.
    • Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
    • The lens can now be removed and replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
100 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G21
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,569
