Ana içeriğe geç
Flip Video Ultra Circuit Board Replacement
Neye ihtiyacın var
    1. Flip Video Ultra Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
      • Unlock the battery cover by sliding the switch to the unlock position.
      FixBot'a Sor
      Yorum Ekle
    2. Flip Video Ultra Circuit Board Replacement: adım 2, 1 resimden 1.
      • Remove the battery cover by sliding it down the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Flip Video Ultra Circuit Board Replacement: adım 3, 1 resimden 1.
      • Remove the batteries
      FixBot'a Sor
      Yorum Ekle
    4. Flip Video Ultra Circuit Board Replacement: adım 4, 1 resimden 1.
      • Slide the black upper casing off from the device.
      FixBot'a Sor
      Yorum Ekle
    5. Flip Video Ultra Circuit Board Replacement: adım 5, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 5, 2 resimden 2.
      • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Flip Video Ultra Circuit Board Replacement: adım 6, 1 resimden 1.
      • Remove the top casing from the bottom to reveal the inner circuit board.
      FixBot'a Sor
      Yorum Ekle
    7. Flip Video Ultra Circuit Board Replacement: adım 7, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 7, 2 resimden 2.
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Flip Video Ultra Circuit Board Replacement: adım 8, 1 resimden 1.
      • Gently separate the circuit board from the casing.
      FixBot'a Sor
      Yorum Ekle
    9. Flip Video Ultra Circuit Board Replacement: adım 9, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 9, 2 resimden 2.
      • Unscrew the single 1mm screw from USB housing unit.
      FixBot'a Sor
      Yorum Ekle
    10. Flip Video Ultra Circuit Board Replacement: adım 10, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 10, 2 resimden 2.
      • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
      FixBot'a Sor
      Yorum Ekle
    11. Flip Video Ultra Circuit Board Replacement: adım 11, 1 resimden 1.
      • Gently pry out the USB housing unit with the Ifxit Opening Tool.
      FixBot'a Sor
      Yorum Ekle
    12. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 2. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 3.
      • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    13. Flip Video Ultra Circuit Board Replacement: adım 13, 1 resimden 1.
      • Unscrew the camera housing unit from the plastic case.
      FixBot'a Sor
      Yorum Ekle
    14. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 2. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 3.
      Bu adımda kullanılan alet:
      • With tweezers, remove the microphone and USB connections.
      FixBot'a Sor
      Yorum Ekle
    15. Flip Video Ultra Circuit Board Replacement: adım 15, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 15, 2 resimden 2.
      • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
      FixBot'a Sor
      Yorum Ekle
    16. Flip Video Ultra Circuit Board Replacement: adım 16, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 16, 2 resimden 2.
      • Remove the single 2.1 mm screw and separate camera from the circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathaniel Ruf
514 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G7
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 1,083
