Ana içeriğe geç
Flip Video Ultra Circuit Board Replacement
Neye ihtiyacın var
  1. Flip Video Ultra Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove the batteries
  4. Flip Video Ultra Circuit Board Replacement: adım 4, 1 resimden 1.
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Circuit Board Replacement: adım 5, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 5, 2 resimden 2.
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Circuit Board Replacement: adım 6, 1 resimden 1.
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Circuit Board Replacement: adım 7, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 7, 2 resimden 2.
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Circuit Board Replacement: adım 8, 1 resimden 1.
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Circuit Board Replacement: adım 9, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 9, 2 resimden 2.
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Circuit Board Replacement: adım 10, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 10, 2 resimden 2.
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Circuit Board Replacement: adım 11, 1 resimden 1.
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 2. Flip Video Ultra Circuit Board Replacement: adım 12, 3 resimden 3.
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Circuit Board Replacement: adım 13, 1 resimden 1.
    • Unscrew the camera housing unit from the plastic case.
  14. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 2. Flip Video Ultra Circuit Board Replacement: adım 14, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With tweezers, remove the microphone and USB connections.
  15. Flip Video Ultra Circuit Board Replacement: adım 15, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 15, 2 resimden 2.
    • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
  16. Flip Video Ultra Circuit Board Replacement: adım 16, 2 resimden 1. Flip Video Ultra Circuit Board Replacement: adım 16, 2 resimden 2.
    • Remove the single 2.1 mm screw and separate camera from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathaniel Ruf
514 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 889
