Ana içeriğe geç
Flip Video Ultra USB connector Replacement
Neye ihtiyacın var
    1. Flip Video Ultra USB connector Replacement, USB connector: adım 1, 1 resimden 1.
      • Unlock the battery cover by sliding the switch to the unlock position.
      FixBot'a Sor
      Yorum Ekle
    2. Flip Video Ultra USB connector Replacement: adım 2, 1 resimden 1.
      • Remove the battery cover by sliding it down the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Flip Video Ultra USB connector Replacement: adım 3, 1 resimden 1.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    4. Flip Video Ultra USB connector Replacement: adım 4, 1 resimden 1.
      • Slide the black upper casing off from the device.
      • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
      FixBot'a Sor
      Yorum Ekle
    5. Flip Video Ultra USB connector Replacement: adım 5, 2 resimden 1. Flip Video Ultra USB connector Replacement: adım 5, 2 resimden 2.
      • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Flip Video Ultra USB connector Replacement: adım 6, 1 resimden 1.
      • Remove the top casing from the bottom to reveal the inner circuit board.
      FixBot'a Sor
      Yorum Ekle
    7. Flip Video Ultra USB connector Replacement: adım 7, 2 resimden 1. Flip Video Ultra USB connector Replacement: adım 7, 2 resimden 2.
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Flip Video Ultra USB connector Replacement: adım 8, 2 resimden 1. Flip Video Ultra USB connector Replacement: adım 8, 2 resimden 2.
      • Gently separate the circuit board from the casing.
      FixBot'a Sor
      Yorum Ekle
    9. Flip Video Ultra USB connector Replacement: adım 9, 2 resimden 1. Flip Video Ultra USB connector Replacement: adım 9, 2 resimden 2.
      • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    10. Flip Video Ultra USB connector Replacement: adım 10, 2 resimden 1. Flip Video Ultra USB connector Replacement: adım 10, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Gently lift the usb connector using the Plastic opening tool.
      • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
      • The connector will be easier to remove if you wiggle the tweezers while lifting.
      FixBot'a Sor
      Yorum Ekle
    11. Flip Video Ultra USB connector Replacement: adım 11, 1 resimden 1.
      • Fully remove the USB connector and replace it with the new USB connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathaniel Ruf
514 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G7
3 Üyeler
15 adet Kılavuz yazıldı
2Kılavuz Yorumları
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Yanıt Paylaş
Where do you purchase the replacement usb connector?
DeEtte Moore - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 1,592
