Ana içeriğe geç
Flip-Flop Line Strap Replacement
Neye ihtiyacın var
  1. Flip-Flop Line Strap Replacement, Line Strap: adım 1, 1 resimden 1.
    • Use the utility scissors to remove the tip of the broken line strap.
    • Try to remove as much of the broken tip as possible.
  2. Flip-Flop Line Strap Replacement: adım 2, 1 resimden 1.
    • Position one 8-inch zip tie underneath the strap line.
    • Head end of the zip tie.
    • Tail end of the zip tie.
    • You can use any color zip tie to match the color of your flip-flop.
    • Zip ties can be purchased from stores such as Walmart, Ace Hardware, and the Dollar Tree.
  3. Flip-Flop Line Strap Replacement: adım 3, 1 resimden 1.
    • Fold the zip tie so that the head end is on top of the line strap.
  4. Flip-Flop Line Strap Replacement: adım 4, 1 resimden 1.
    • Insert the tail end through the head end to make a loop.
  5. Flip-Flop Line Strap Replacement: adım 5, 1 resimden 1.
    • Tighten the loop by pulling on the tail end of the zip tie.
    • Make the loop approximately a half-inch.
  6. Flip-Flop Line Strap Replacement: adım 6, 1 resimden 1.
    • Cut off the extra zip tie material.
  7. Flip-Flop Line Strap Replacement: adım 7, 1 resimden 1.
    • Pass the metal flat washer through the second 8-inch zip tie.
    • 4.8mm metal flat washer.
  8. Flip-Flop Line Strap Replacement: adım 8, 1 resimden 1.
    • Pass the tail end through the hole on the bottom of the flip-flop.
  9. Flip-Flop Line Strap Replacement: adım 9, 1 resimden 1.
    • Pass the tail end through the loop of the first zip tie.
  10. Flip-Flop Line Strap Replacement: adım 10, 2 resimden 1. Flip-Flop Line Strap Replacement: adım 10, 2 resimden 2.
    • Return the tail end back through the hole.
    • Pass the tail end into the 4.8mm metal flat washer.
    • Turn the flip-flop on its side for a better view.
  11. Flip-Flop Line Strap Replacement: adım 11, 1 resimden 1.
    • Push the 4.8mm metal flat washer inside the hole of the flip-flop.
  12. Flip-Flop Line Strap Replacement: adım 12, 1 resimden 1.
    • Insert the tail end into the head end.
  13. Flip-Flop Line Strap Replacement: adım 13, 2 resimden 1. Flip-Flop Line Strap Replacement: adım 13, 2 resimden 2.
    • Adjust the length of the zip tie to create a snug fit between your toes.
    • Push the loop of the tail into the hole.
    • Pull on the tail end until you're satisfied with the length.
    • Turn the flip-flip over occasionally to check the length of the toe piece as needed.
    • Length of toe piece.
    • This step might take some trial and error.
  14. Flip-Flop Line Strap Replacement: adım 14, 1 resimden 1.
    • Push the head end into the hole of the flip-flop.
    • It's okay if the head end does not fit perfectly inside the hole. It will eventually fit deeper into the hole from walking.
  15. Flip-Flop Line Strap Replacement: adım 15, 1 resimden 1.
  16. Flip-Flop Line Strap Replacement: adım 16, 1 resimden 1.
    • Cut off about a 1-inch piece of heavy duty duct tape.
    • You can use any color heavy duty duct tape to match the color of your flip-flop.
  17. Flip-Flop Line Strap Replacement: adım 17, 1 resimden 1.
    • Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
    • If you don't have heavy duty duct tape, use two pieces of regular duct tape.
Sonuç
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
6 farklı kişi bu kılavuzu tamamladı.
Dominique Hall
505 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Toby Robinson - Yanıt
Awesome. Thank you!
Windogalaz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 36
Son 30 gün: 109
Her zaman: 27,758
