Ana içeriğe geç
Flipper Zero NFC RFID board Replacement
Neye ihtiyacın var
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero NFC RFID board Replacement, Remove the microSD card: adım 2, 1 resimden 1.
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero NFC RFID board Replacement, Remove the screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero NFC RFID board Replacement, Open the back cover: adım 4, 3 resimden 1. Flipper Zero NFC RFID board Replacement, Open the back cover: adım 4, 3 resimden 2. Flipper Zero NFC RFID board Replacement, Open the back cover: adım 4, 3 resimden 3.
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero NFC RFID board Replacement, Seperate the chassis from the top cover: adım 5, 2 resimden 1. Flipper Zero NFC RFID board Replacement, Seperate the chassis from the top cover: adım 5, 2 resimden 2.
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero NFC RFID board Replacement, Disconnect the battery: adım 6, 1 resimden 1.
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero NFC RFID board Replacement, Disconnect the ribbon cables: adım 7, 2 resimden 1. Flipper Zero NFC RFID board Replacement, Disconnect the ribbon cables: adım 7, 2 resimden 2.
    iFixit Opening Picks (Set of 6)
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
    • Once the connectors are unlocked, carefully pull out the ribbon cables.
  7. Flipper Zero NFC RFID board Replacement, Remove the NFC RFID board: adım 8, 2 resimden 1. Flipper Zero NFC RFID board Replacement, Remove the NFC RFID board: adım 8, 2 resimden 2.
    • To remove the NFC RFID board, release it from the latches in the sequence shown by pressing on the edge of the chassis near each latch.
    • Gently lift the NFC RFID board out of the chassis once all latches are released.
Sonuç
Sebastian
31.811 İtibar
71 adet Kılavuz yazıldı
1Rehber Yorum
I have a quick question- is there any place to buy the NFC board? I can't seem to find any place on the internet for it :c
msgraves - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 83
Her zaman: 2,869
