Giriş
Over time, the hose on your steel floor drive pump may wear or puncture. Use this guide to install a new hose.
Neye ihtiyacın var
Use a pair of pliers to loosen the hose pinch by turning it counterclockwise a couple of turns.
Continue to loosen the hose pinch by hand until it comes free from its threads.
Slide the hose pinch down the tube so that it does not interfere with removing the hose.
Bir başkası bu kılavuzu tamamladı.
