Giriş
Replace the pressure gauge in your classic floor drive pump if the gauge appears to be inaccurate, is malfunctioning or has stopped working all together.
Neye ihtiyacın var
Using a flat head screwdriver, pry up an edge of the gauge cover.
Remove the gauge cover.
Pry up a corner of the gauge face plate.
Use pliers to pull off the gauge face plate.
Use pliers to pry out the internal gauge mechanics.
Using pliers, grip the exposed brass piece and unthread the gauge by rotating it counter-clockwise.
Pull the gauge out of its housing.
Remove the O-ring at the bottom of the threaded hole.
Place a new O-ring into the hole.
Apply medium-strength Loctite (green, 290) to the threads on the new gauge.
Thread the new gauge into the floor pump by turning it clockwise in its housing.
Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
Allow at least 30 minutes for the thread locker to set.
Test the pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
