Ana içeriğe geç
Floor Pump Gauge Replacement
Neye ihtiyacın var
  1. Floor Pump Gauge Replacement, Removing the Gauge Cover: adım 1, 2 resimden 1. Floor Pump Gauge Replacement, Removing the Gauge Cover: adım 1, 2 resimden 2.
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: adım 2, 3 resimden 1. Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: adım 2, 3 resimden 2. Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: adım 2, 3 resimden 3.
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful not to cut yourself when prying off the face plate, as the edges are sharp.
    • Use pliers to pry out the internal gauge mechanics.
  3. Floor Pump Gauge Replacement, Removing the Old Gauge: adım 3, 2 resimden 1. Floor Pump Gauge Replacement, Removing the Old Gauge: adım 3, 2 resimden 2.
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating it counter-clockwise.
    • Pull the gauge out of its housing.
  4. Floor Pump Gauge Replacement, Replacing the Gauge O-rings: adım 4, 2 resimden 1. Floor Pump Gauge Replacement, Replacing the Gauge O-rings: adım 4, 2 resimden 2.
    • Remove the O-ring at the bottom of the threaded hole.
    • Place a new O-ring into the hole.
  5. Floor Pump Gauge Replacement, Applying Threadlocker: adım 5, 1 resimden 1.
    • Apply medium-strength Loctite (green, 290) to the threads on the new gauge.
    • Apply a thin layer, but make sure it covers all the threads.
  6. Floor Pump Gauge Replacement, Installing the New Gauge: adım 6, 3 resimden 1. Floor Pump Gauge Replacement, Installing the New Gauge: adım 6, 3 resimden 2. Floor Pump Gauge Replacement, Installing the New Gauge: adım 6, 3 resimden 3.
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test the pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Bitiş Çizgisi
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 2,871
