Giriş
You may notice that your pump is not able to achieve the pressures it used to be able to. Your pump may be even making unusual sounds while pumping. This could be an indication that the O-rings in the pump are worn and can't make a proper seal. Use this guide to replace your worn O-rings.
Aletler
Parçalar
Bir başkası bu kılavuzu tamamladı.
