Ana içeriğe geç
Floor Pump O-Rings Replacement
Neye ihtiyacın var
    1. Floor Pump O-Rings Replacement, O-Rings: adım 1, 1 resimden 1.
      • Detach the hose from its holder.
      FixBot'a Sor
      Yorum Ekle
    2. Floor Pump O-Rings Replacement: adım 2, 2 resimden 1. Floor Pump O-Rings Replacement: adım 2, 2 resimden 2.
      • Hold the base of the pump steady and twist the barrel counter-clockwise by hand until it completely unthreads.
      • If you are having troubles stabilizing the base and twisting the barrel, try standing on the base and using both hands to loosen the barrel.
      • Lift the barrel off the base.
      • When removing the barrel, be sure not to lose the bump stop O-ring. It may stick to the pump base, may be stuck inside the barrel, or may fall out when you remove the barrel.
      FixBot'a Sor
      Yorum Ekle
    3. Floor Pump O-Rings Replacement: adım 3, 1 resimden 1.
      • Lift the pump handle until the top cap is expsoed
      FixBot'a Sor
      Yorum Ekle
    4. Floor Pump O-Rings Replacement: adım 4, 3 resimden 1. Floor Pump O-Rings Replacement: adım 4, 3 resimden 2. Floor Pump O-Rings Replacement: adım 4, 3 resimden 3.
      • Place the ends of needle nose pliers into the top cap holes and turn counter-clockwise until the cap is loose.
      • Finish removing the top cap by hand.
      • Pull the pump plunger out of the barrel.
      FixBot'a Sor
      Yorum Ekle
    5. Floor Pump O-Rings Replacement: adım 5, 2 resimden 1. Floor Pump O-Rings Replacement: adım 5, 2 resimden 2.
      • Use a small flathead screwdriver to remove the plunger O-ring.
      • Use the screwdriver to remove the upper bump stop O-ring.
      • Install new O-rings.
      • Be careful not to over-stretch or cut the O-rings if you are using the screwdriver to install them.
      FixBot'a Sor
      Yorum Ekle
    6. Floor Pump O-Rings Replacement: adım 6, 2 resimden 1. Floor Pump O-Rings Replacement: adım 6, 2 resimden 2.
      • Remove the lower bump stop O-ring from the pump base.
      • Remove and replace the base O-ring.
      FixBot'a Sor
      Yorum Ekle
    7. Floor Pump O-Rings Replacement: adım 7, 3 resimden 1. Floor Pump O-Rings Replacement: adım 7, 3 resimden 2. Floor Pump O-Rings Replacement: adım 7, 3 resimden 3.
      • Insert the tips of needle nose pliers into the base cap holes and turn it counter-clockwise until it completely unthreads.
      • Remove the base cap from the pump base.
      • Remove and replace the base cap O-ring.
      • Re-assemble the pump using these instructions backwards.
      • Don't forget to set a new bump stop O-ring on top of the pump base before re-installing the pump barrel.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
iRobot
1 İtibar
633 adet Kılavuz yazıldı
1Rehber Yorum
I was looking for ideas on how to “make" an O- ring. It can't be that difficult. I'll update when the plan comes together.?
RBizerka - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 71
Her zaman: 7,201
