Ana içeriğe geç
Fluance RT83 Belt Replacement
Neye ihtiyacın var
  1. Fluance RT83 Belt Replacement, Belt: adım 1, 1 resimden 1.
    • Unplug the turntable.
  2. Fluance RT83 Belt Replacement: adım 2, 1 resimden 1.
    • Lock the tonearm in place with the tonearm clip.
    • If the tonearm is not locked in place, it could move around and potentially damage the needle
  3. Fluance RT83 Belt Replacement: adım 3, 1 resimden 1.
    • Lift the rubber mat and place it to the side.
    • The rubber mat should come off easily, as it is simply resting on top of the metal platter.
  4. Fluance RT83 Belt Replacement: adım 4, 1 resimden 1.
    • Unhook the drive belt from the motor pulley.
    • The drive belt is carefully wrapped around the motor pulley, so it is important to unhook it gently.
  5. Fluance RT83 Belt Replacement: adım 5, 1 resimden 1.
    • Remove the drive belt from the metal platter.
  6. Fluance RT83 Belt Replacement: adım 6, 1 resimden 1.
    • Grab the new drive belt.
    • Wrap the new drive belt around the motor pulley.
    • Note: When reassembling the turntable, don't forget to wrap the new drive belt around the motor pulley.
  7. Fluance RT83 Belt Replacement: adım 7, 1 resimden 1.
    • Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
    • If you are having difficulty wrapping the new drive belt around the metal platter, go very slowly and gently. Patience may be required for this step.
  8. Fluance RT83 Belt Replacement: adım 8, 1 resimden 1.
    • Make sure your drive belt is flush against the platter.
    • It is very important there are no twists in your drive belt.
  9. Fluance RT83 Belt Replacement: adım 9, 1 resimden 1.
    • Give your metal platter a gentle spin clockwise.
    • When spinning, the platter should continue to spin for a few seconds on its own.
    • If your metal platter is able to spin with the new drive belt attached, you have successfully installed your drive belt.
  10. Fluance RT83 Belt Replacement: adım 10, 1 resimden 1.
    • Place the rubber mat back on top of the metal tray platter.
Sonuç
Test by playing a record.
Austin Daniel
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 512
