Ana içeriğe geç
Fluke 77 Series III Dial Replacement
Neye ihtiyacın var
  1. Fluke 77 Series III Dial Replacement, Front Panel: adım 1, 1 resimden 1.
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
    FixBot'a Sor
    Yorum Ekle
  2. Fluke 77 Series III Dial Replacement: adım 2, 1 resimden 1.
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  3. Fluke 77 Series III Dial Replacement: adım 3, 2 resimden 1. Fluke 77 Series III Dial Replacement: adım 3, 2 resimden 2.
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
    FixBot'a Sor
    Yorum Ekle
  4. Fluke 77 Series III Dial Replacement, Dial: adım 4, 1 resimden 1.
    • Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
    • Firmly press down on the dial axle to separate the dial from the front panel.
    • If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
    FixBot'a Sor
    Yorum Ekle
  5. Fluke 77 Series III Dial Replacement: adım 5, 1 resimden 1.
    • With the dial loosened, pull the white plastic rotating piece until it comes off the dial axle.
    FixBot'a Sor
    Yorum Ekle
  6. Fluke 77 Series III Dial Replacement: adım 6, 1 resimden 1.
    • Finally, push again on the dial axle with your thumb while at the same time pulling the dial off the front panel with your other hand .
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kishan Patel
752 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G10
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 62
Her zaman: 3,455
