Ana içeriğe geç
Fluke 77 Series III Fuse Replacements
Neye ihtiyacın var
  1. Fluke 77 Series III Fuse Replacements, Front Panel: adım 1, 1 resimden 1.
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
    FixBot'a Sor
    Yorum Ekle
  2. Fluke 77 Series III Fuse Replacements: adım 2, 1 resimden 1.
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  3. Fluke 77 Series III Fuse Replacements: adım 3, 2 resimden 1. Fluke 77 Series III Fuse Replacements: adım 3, 2 resimden 2.
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
    FixBot'a Sor
    Yorum Ekle
  4. Fluke 77 Series III Fuse Replacements, Battery: adım 4, 2 resimden 1. Fluke 77 Series III Fuse Replacements, Battery: adım 4, 2 resimden 2.
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
    FixBot'a Sor
    Yorum Ekle
  5. Fluke 77 Series III Fuse Replacements: adım 5, 2 resimden 1. Fluke 77 Series III Fuse Replacements: adım 5, 2 resimden 2.
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Fluke 77 Series III Fuse Replacements, Fuse: adım 6, 2 resimden 1. Fluke 77 Series III Fuse Replacements, Fuse: adım 6, 2 resimden 2.
    • Replace a fuse only with a fuse identical in type, voltage rating, and current rating as specified by the back panel fuse rating label or the Fluke 77 Series III Service Manual. Inserting the wrong replacement fuse could create a fire hazard.
    • Locate the fuses near the bottom left corner inside the device.
    • Take note of which fuses belong in which location before removal. They are NOT interchangeable.
    • The .440 Amp fuse is located in the upper left hand fuse holder.
    • The 11 Amp fuse is located in the lower right hand fuse holder.
    • Lift the rounded edge of the fuse with one finger until that side is completely out of its holder.
    FixBot'a Sor
    Yorum Ekle
  7. Fluke 77 Series III Fuse Replacements: adım 7, 1 resimden 1.
    • Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
    • The fuse in the upper left corner can be tricky to remove. Use a plastic opening tool if needed.
    • Repeat steps 4 and 5 to remove the other fuse if you are replacing both fuses or if you are replacing a different part further on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Bombardier Shaw
1.018 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G10
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Its not that fuse but one like it on the main board in the stereo
Jennie Walters - Yanıt Paylaş
Don’t see a fuse on mine. No brand name. New battery. Continuity buzzer not working. And, Voltages Both AC/DC) show . When n ot connected to a voltage. ? Nothing looks out of place. Looks clean inside. Only thing i can think of is trying to get to the switch. That doesn’t look easy. Printed circuit board has to be pryed out. Looks like. WAIT,ther does look like a place for a fuse. But,,nothing there. How didi it work,,at all. Have had it for about 13 years.
rfloch4 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 77
Her zaman: 8,207
