Ana içeriğe geç
FlySky FS-TH9X Joystick too Loose or too Tight
Neye ihtiyacın var
  1. FlySky FS-TH9X Joystick too Loose or too Tight, FlySky FS-TH9X Disassembly: adım 1, 1 resimden 1.
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick too Loose or too Tight: adım 2, 1 resimden 1.
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick too Loose or too Tight: adım 3, 1 resimden 1.
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick too Loose or too Tight: adım 4, 1 resimden 1.
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick too Loose or too Tight, FlySky FS-TH9X Joystick too Loose or too Tight: adım 5, 1 resimden 1.
    • Referring to dissasembally guide open the remote to expose the inside
    • Once opened, locate the resistance plate that is highlighted
  6. FlySky FS-TH9X Joystick too Loose or too Tight: adım 6, 1 resimden 1.
    • Tighten or loosen the highlighted screw to desired level of resistance.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 98
