Ana içeriğe geç
Flydigi Apex 5 USB-C Daughterboard Replacement
Neye ihtiyacın var
  1. Flydigi Apex 5 USB-C Daughterboard Replacement, Battery: adım 1, 2 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement, Battery: adım 1, 2 resimden 2.
    • Orient the controller so that its back is facing you.
    • Apply firm downward pressure to remove both the M3 and M4 back paddles.
    FixBot'a Sor
    Yorum Ekle
  2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 2, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 2, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 2, 3 resimden 3.
    • Turn the controller over so its front faces you.
    • Remove the D-pad by firmly pulling it away from the body of the controller.
    FixBot'a Sor
    Yorum Ekle
  3. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 3, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 3, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 3, 3 resimden 3.
    • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
    FixBot'a Sor
    Yorum Ekle
  4. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 4, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 4, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 4, 3 resimden 3.
    • Remove the small cover from the rear of the controller by pushing it upward.
    • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 5, 2 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 5, 2 resimden 2.
    • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 6, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 6, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 6, 3 resimden 3.
    • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
    • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
    FixBot'a Sor
    Yorum Ekle
  7. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 7, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 7, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 7, 3 resimden 3.
    • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 8, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 8, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 8, 3 resimden 3.
    • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
    • Pull the power supply cable through the plastic cable guides.
    FixBot'a Sor
    Yorum Ekle
  9. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 9, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 9, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 9, 3 resimden 3.
    • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
    • Pry up the battery with the plastic hook and pry tool.
    • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: adım 10, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: adım 10, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: adım 10, 3 resimden 3.
    • Press a prong of each side of the angled tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
    • Lift the motor directly upward out of its casing.
    FixBot'a Sor
    Yorum Ekle
  11. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 11, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 11, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 11, 3 resimden 3.
    • Press a prong of each side of the curved tip tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
    FixBot'a Sor
    Yorum Ekle
  12. Flydigi Apex 5 USB-C Daughterboard Replacement, USB-C Daughterboard: adım 12, 2 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement, USB-C Daughterboard: adım 12, 2 resimden 2.
    • Remove the USB-C faceplate by inserting the spudger as shown, pushing the spudger forward while twisting slightly.
    FixBot'a Sor
    Yorum Ekle
  13. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 13, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 13, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 13, 3 resimden 3.
    • Remove the two 10mm screws using a Phillips #0 screwdriver.
    • Remove the plastic battery mold by lifting away from the controller.
    FixBot'a Sor
    Yorum Ekle
  14. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 14, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 14, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 14, 3 resimden 3.
    • Remove the four 5mm screws using a Phillips #00 screwdriver.
    • Remove the two vibration motor housings by pulling away from the controller.
    FixBot'a Sor
    Yorum Ekle
  15. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 15, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 15, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 15, 3 resimden 3.
    • Remove the three 10mm screws using a Phillips #1 screwdriver.
    • Use your index finger to push on the left joystick, while also pulling on the motherboard with your other hand.
    FixBot'a Sor
    Yorum Ekle
  16. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 16, 2 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers to push against the black latch to open the ribbon connector.
    • Use the pair of tweezers to gently pull the ribbon out of its connection.
    FixBot'a Sor
    Yorum Ekle
  17. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 17, 2 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 17, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 5mm screws connecting the D-pad to the front of the controller.
    • Remove the black plastic cover holding the D-pad to the front of the controller.
    FixBot'a Sor
    Yorum Ekle
  18. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 18, 3 resimden 1. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 18, 3 resimden 2. Flydigi Apex 5 USB-C Daughterboard Replacement: adım 18, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the two 7mm screws.
    • Remove the plastic bridge covering the USB-C daughterbord.
    • Pull the USB-C daughterboard away from the front of the controller.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aiden Sawyer
415 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 48
Her zaman: 134
