Ana içeriğe geç
Giriş
This guide will assist you to change the battery on a fob watch. These watches are worn on the chest, and are often used by nurses and other healthcare professionals to easily see the time, aid in clinical assessment, and to maintain infection control by avoiding the use of a wristwatch.
The battery in a fob watch can be changed easily.
Parçalar
Hiçbir parça belirtilmedi.
  1. Fob watch Battery Replacement, Battery: adım 1, 2 resimden 1. Fob watch Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the watch from the silicon casing and turn the watch over.
    • Locate the small indent on the edge of the back plate.
  2. Fob watch Battery Replacement: adım 2, 3 resimden 1. Fob watch Battery Replacement: adım 2, 3 resimden 2. Fob watch Battery Replacement: adım 2, 3 resimden 3.
    • Wedge the tip of a Jimmy underneath the indent to lift off the back plate.
    • Use a safe tool to avoid accidents.
  3. Fob watch Battery Replacement: adım 3, 2 resimden 1. Fob watch Battery Replacement: adım 3, 2 resimden 2.
    • Insert a spudger underneath the white plastic that holds the movement in place.
    • Lift the plastic up and remove.
    • Use an ESD safe tool near the battery or other internal components.
  4. Fob watch Battery Replacement: adım 4, 2 resimden 1. Fob watch Battery Replacement: adım 4, 2 resimden 2.
    • Locate the small circle battery
    • Wedge the tip of the spudger underneath the small circle battery and lift it out.
    • Do not use a knife or other metal tool with a battery or other internal component as this could cause damage.
  5. Fob watch Battery Replacement: adım 5, 2 resimden 1. Fob watch Battery Replacement: adım 5, 2 resimden 2.
    • Insert the new battery.
Sonuç
To reassemble your watch, follow these instructions in reverse order. Pull out and turn the dial on the side of the watch to adjust the time.
Bir başkası bu kılavuzu tamamladı.
Lilli Morgan
148 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 90
Son 30 gün: 453
Her zaman: 10,454
