Ana içeriğe geç
Foldable Grocery Cart Wheels Replacement
Neye ihtiyacın var
  1. Foldable Grocery Cart Wheels Replacement, Wheels: adım 1, 3 resimden 1. Foldable Grocery Cart Wheels Replacement, Wheels: adım 1, 3 resimden 2. Foldable Grocery Cart Wheels Replacement, Wheels: adım 1, 3 resimden 3.
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: adım 2, 2 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 2, 2 resimden 2.
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: adım 3, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 3, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 3, 3 resimden 3.
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: adım 4, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 4, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 4, 3 resimden 3.
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: adım 5, 2 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 5, 2 resimden 2.
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: adım 6, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 6, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 6, 3 resimden 3.
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: adım 7, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 7, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 7, 3 resimden 3.
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: adım 8, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 8, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 8, 3 resimden 3.
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: adım 9, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 9, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 9, 3 resimden 3.
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: adım 10, 3 resimden 1. Foldable Grocery Cart Wheels Replacement: adım 10, 3 resimden 2. Foldable Grocery Cart Wheels Replacement: adım 10, 3 resimden 3.
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Saba Aafreen
232 İtibar
1 Kılavuz yazıldı
Bir Yorum
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 84
Son 30 gün: 350
Her zaman: 8,167
