Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If you have a foldable grocery cart or shopping trolly, that has its front wheels all worn out, then this guide will assist you in replacing the tattered wheels with new ones so you don’t have to worry about buying another cart. Damaged wheels of your grocery cart can cause your cart to not steer properly or even worse, collapse on the spot. It is important to replace them to avoid such situations and unnecessary expenses.
For the replacement, you can get an extra pair of wheels by buying new ones or use wheels that are in good condition from another cart that is not being used anymore. Just make sure that the wheels are of similar size to the old ones and that the hole is big enough to slide through the axle of the cart you’re currently using (some wheel sizes and center hole sizes may vary, so get a pair of wheels that are compatible with your grocery cart). Before starting, make sure your work area is open and free of any obstacles.
Neye ihtiyacın var
Using a large needle nose plier, take out the stoppers from each side of the axle.
2 farklı kişi bu kılavuzu tamamladı.
