Ana içeriğe geç
Ford Focus Door Interior dome light assembly Replacement
Neye ihtiyacın var
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: adım 1, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: adım 1, 2 resimden 2.
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: adım 2, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 2, 2 resimden 2.
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: adım 3, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 3, 2 resimden 2.
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: adım 4, 3 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 4, 3 resimden 2. Ford Focus Door Interior dome light assembly Replacement: adım 4, 3 resimden 3.
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: adım 5, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 5, 2 resimden 2.
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: adım 6, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 6, 2 resimden 2.
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: adım 7, 3 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 7, 3 resimden 2. Ford Focus Door Interior dome light assembly Replacement: adım 7, 3 resimden 3.
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: adım 8, 3 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 8, 3 resimden 2. Ford Focus Door Interior dome light assembly Replacement: adım 8, 3 resimden 3.
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: adım 9, 3 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 9, 3 resimden 2. Ford Focus Door Interior dome light assembly Replacement: adım 9, 3 resimden 3.
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: adım 10, 3 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 10, 3 resimden 2. Ford Focus Door Interior dome light assembly Replacement: adım 10, 3 resimden 3.
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: adım 11, 2 resimden 1. Ford Focus Door Interior dome light assembly Replacement: adım 11, 2 resimden 2.
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cassidy
241 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 23,073
