Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pop the hood of the 2007 Ford Focus using the pull lever under the steering wheel.
Secure the hood with the hood prop on the left side of the engine.
To disconnect the battery follow steps 2-4.
Loosen the bracket with the wrench.
Remove the top cover.
Remove the negative cable (usually black in color and labeled - or "Negative" ) by turning the nut clockwise with the wrench.
Remove the positive cable (usually red in color and labeled with + or "Positive")by turning the nut clockwise with the wrench.
Unscrew the first anchor bolt that attaches the metal clip to the engine mount.
Unscrew the second anchor bolt that secures the metal mount.
Detach the wiring harness by holding down the tab on the top of the clip.
Pull apart.
Obtain the new capacitor and reattach it by reversing the same steps you followed to disconnect the old capacitor.
6 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Do I have to have this part as it keeps arcing on the body or frame of my car and shorten out my ignition fuse. So do I have to have this part because I noticed when I unplugged it my car cranked up and ran because I forgot to plug it back in. How long can I run without it and what damage does it do? Because I know it has to do with the radio interference with within the steering wheel or something like that and I have no radio so I don't know if that matters
The wires on mine broke off completely and without the capacitor my focus won't even crank over at all..
