Giriş
In this project I will help Ford Taurus car owners avoid costs on replacing bulbs when they can do it by themselves. I consider emphasizing on use of genuine parts when repairing the car because genuine parts last longer than the counterfeit parts. Thus, this guide aims at helping fix back lights via a simple procedure, emphasis on safety of the repairer and the car in a cost-effective method.
Parçalar
  1. Remove the plastic clips which fasten the outside cover. Remove the plastic clips which fasten the outside cover. Remove the plastic clips which fasten the outside cover.
    • Remove the plastic clips which fasten the outside cover.
  2. Pull out the cover to access the housing
    • Pull out the cover to access the housing
  3. Using wrench to remove the four bolts to open the housing. Using wrench to remove the four bolts to open the housing.
    • Using wrench to remove the four bolts to open the housing.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Open the housing to access the bulb set and remove it out to replace it. Open the housing to access the bulb set and remove it out to replace it. Open the housing to access the bulb set and remove it out to replace it.
    • Open the housing to access the bulb set and remove it out to replace it.
  6. Put the new light bulb and make sure it is working. Put the new light bulb and make sure it is working. Put the new light bulb and make sure it is working.
    • Put the new light bulb and make sure it is working.
  7. Place the housing cover on and return the bolts. Place the housing cover on and return the bolts. Place the housing cover on and return the bolts.
    • Place the housing cover on and return the bolts.
  8. Return cover and use the plastic clips to fasten it. Return cover and use the plastic clips to fasten it.
    • Return cover and use the plastic clips to fasten it.
Sonuç
sultan alqahtani
145 İtibar
1 Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 86
