Giriş
After too many charging cycles, the battery's capacity will be decreased. This is true for any Lithium-ion battery. Luckily the replacement of the battery in this device is very simple.
Neye ihtiyacın var
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Bir başkası bu kılavuzu tamamladı.
