Ana içeriğe geç
Fosera Scandle 200 Motherboard Removal
Neye ihtiyacın var
  1. Fosera Scandle 200 Motherboard Removal, Motherboard Removal: adım 1, 1 resimden 1.
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Motherboard Removal: adım 2, 1 resimden 1.
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Motherboard Removal: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Motherboard Removal: adım 4, 1 resimden 1.
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Motherboard Removal: adım 5, 1 resimden 1.
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
Bitiş Çizgisi
Vladislav Ignatov
597 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 306
