Giriş
This guide demonstrates how to replace the battery in a Fossil FS-4494 watch. The alternate model of this watch is a Fossil AM 4494. Today, when a watch—especially an older model with a small battery—stops working, people often discard it in favor of modern alternatives with built-in technology and rechargeable batteries.
If your watch is not ticking, the battery is likely dead and needs to be replaced.
A couple of warnings before you begin this repair:
- Be sure to note the battery type before you recycle your old battery. If you do not get an identical battery, the watch will not work.
- The watch parts are fragile, so be extremely careful when taking out the battery and replacing it.
- The battery holder inside the watch can easily be broken
- Do not rush the process, as moving through each step too fast can cause damage to watch components
- The watch cover on the back is slippery, and it may take you several tries to open it with your needle-nose pliers.
- Alternatively, use a specific watch back removal tool to make this process easier.
- Be careful not to force the watch cover open with your needle-nose pliers, as the pliers can slip and scratch the cover of the watch.
Neye ihtiyacın var
Look closely at the battery, you will see writing on the surface of the battery. This writing will give the model code for the battery.
Check the model code for the new battery before installing the battery inside the watch. If the model code for the new battery does not match the model code for the original battery, you must purchase another battery which has the correct model code.
