Ana içeriğe geç
Fossil Q Marshal Gen 2 Battery Replacement
Neye ihtiyacın var
  1. Fossil Q Marshal Gen 2 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Battery Replacement: adım 2, 1 resimden 1.
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Battery Replacement: adım 3, 2 resimden 1. Fossil Q Marshal Gen 2 Battery Replacement: adım 3, 2 resimden 2.
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Battery Replacement: adım 4, 1 resimden 1.
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Battery Replacement: adım 5, 3 resimden 1. Fossil Q Marshal Gen 2 Battery Replacement: adım 5, 3 resimden 2. Fossil Q Marshal Gen 2 Battery Replacement: adım 5, 3 resimden 3.
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Battery Replacement, Battery: adım 6, 1 resimden 1.
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
  7. Fossil Q Marshal Gen 2 Battery Replacement: adım 7, 2 resimden 1. Fossil Q Marshal Gen 2 Battery Replacement: adım 7, 2 resimden 2.
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
    Ciao! Ho un Fossil Q Founder (DW2e) Gen 2. E’ lo stesso tipo di batteria ricaricabile? E’ possibile conoscere il tipo di batteria e dove acquistarla? Grazie 1000, sto impazzendo:-)
    Riccardo Filippi - Yanıt
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Clay Walker
752 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Harley Fall 2017 IUPUI, Team S2-G5, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G5
3 Üyeler
6 adet Kılavuz yazıldı
13 Yorum
I have read your awesome guide. This is really helpful.
https://powerbank-online.com/reviews/bat...
Ellen Sam - Yanıt
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
Rafael “Satriabhi” Atheya - Yanıt
model battery?
oleksiyuk - Yanıt
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
dustykeith17 - Yanıt
Help! I can’t find a replacement battery.
Pedro Pimentel - Yanıt
Can't find this model number available anywhere in less than 1000 pieces to buy . Kinda disappointed. On my watch the battery swelled and pushed the display out of the casing which made the disassembly easier but now it's just sat in a bag since I cant find a replacement. Ordered one of ebay that showed up when I searched for this and turned out to be a different model with a different connector
casper denis - Yanıt
Had the exact same issue
nicolas fuchs -
same problem, easy to open, but hard to find the replacement battery.
anyone with a link? looks like an intel battery inside…
fossil don`t care about selling the battery`s they just what you to buy a new watch
theo buiatti - Yanıt
Anyone find a battery yet?
Badgersinblack suits - Yanıt
So it’s 2021, but still I can’t find a battery on the market
msul.nma - Yanıt
GeLar Store on AliExpress.
Antony Hollingworth -
from where can i get the battery plz do you shop to egypt or dubai
amira.hassanamin - Yanıt
I have a Michael Kors Smartwatch MKT5003 (battery dead), that it is manufactured by FOSSIL, do you know which is the compatible model? which is the battery number and where do I get the replacement battery??
I need help, please...
Pablo Ariel Olivera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 73
Son 30 gün: 300
Her zaman: 40,966
