Ana içeriğe geç
Fossil Q Venture Gen 3 Battery Replacement
  1. Fossil Q Venture Gen 3 Battery Replacement, Battery: adım 1, 3 resimden 1. Fossil Q Venture Gen 3 Battery Replacement, Battery: adım 1, 3 resimden 2. Fossil Q Venture Gen 3 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • First, use a screwdriver to remove the band from the device.
  2. Fossil Q Venture Gen 3 Battery Replacement: adım 2, 3 resimden 1. Fossil Q Venture Gen 3 Battery Replacement: adım 2, 3 resimden 2. Fossil Q Venture Gen 3 Battery Replacement: adım 2, 3 resimden 3.
    • Once you remove the band, take a screwdriver and remove the four screws holding the backplate in place.
  3. Fossil Q Venture Gen 3 Battery Replacement: adım 3, 3 resimden 1. Fossil Q Venture Gen 3 Battery Replacement: adım 3, 3 resimden 2. Fossil Q Venture Gen 3 Battery Replacement: adım 3, 3 resimden 3.
    • The inside of the watch will be exposed. Now, you can disconnect all the golden connections (battery, display, etc) and carefully loosen the battery housing from the shell.
  4. Fossil Q Venture Gen 3 Battery Replacement: adım 4, 3 resimden 1. Fossil Q Venture Gen 3 Battery Replacement: adım 4, 3 resimden 2. Fossil Q Venture Gen 3 Battery Replacement: adım 4, 3 resimden 3.
    • When the board is removed, the battery will be stuck in place with an adhesive inside the black plastic housing. Pry the battery out gently to remove it from the board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris Brunston
183 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-1, Kershman Fall 2024 CSU Los Angeles, Team 2-1, Kershman Fall 2024 üyesi
CSULA-KERSHMAN-F24S2G1
5 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 898
