Ana içeriğe geç
Giriş
This guide uses Push-pins and a blunt object such as a hammer. There is potential to hurt yourself with the pin or the blunt object. In this case, the blunt object used was the handles of scissors so also be aware of the potential to cut yourself from the scissors.
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate the link on the band with arrows pointing in opposite directions.
    • Locate the link on the band with arrows pointing in opposite directions.
    • Place push pin into the hole on one side of the link.
  2. Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Hit the push pin with the blunt object (we used scissors) until the small metal rod sticks out from the link.
    • Pull the rod out using your fingers.
    • Repeat on the other side to remove the entire link.
  3. To replace the link, insert the open end of one of the connected links into the open end of the new link. Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
    • To replace the link, insert the open end of one of the connected links into the open end of the new link.
    • Place the rod into the aligning holes and use the blunt object to hammer the rod into the link.
Sonuç
Zachary Price
549 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G10
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 57
