Ana içeriğe geç
Fossil Speedway Watch TI-5061 Battery Replacement
Neye ihtiyacın var
  1. Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: adım 1, 3 resimden 1. Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: adım 1, 3 resimden 2. Fossil Speedway Watch TI-5061 Battery Replacement, Clasp: adım 1, 3 resimden 3.
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Battery Replacement, Back: adım 2, 1 resimden 1.
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Battery Replacement, Battery: adım 3, 2 resimden 1. Fossil Speedway Watch TI-5061 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Place the tweezers around the battery.
    • Firmly grip the battery with the tweezers.
    • Pull the battery out and replace it with a new 371 Renata watch battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Caleb
370 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Amido Spring 2015 Cal Poly, Team 14-10, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G10
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 67
Her zaman: 4,867
