Ana içeriğe geç
Fossil Speedway Watch TI-5061 Time Setting Dial Replacement
Neye ihtiyacın var
  1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: adım 1, 3 resimden 1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: adım 1, 3 resimden 2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Clasp: adım 1, 3 resimden 3.
    • Keep clasp in open position.
    • Push one of the spring-loaded pins out of the hole with a Push-pin.
    • Wiggle watch band and clasp till free from each other.
  2. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Back: adım 2, 1 resimden 1.
    • Fit the blades of a pair of scissors into the grooves of the screw back.
    • Twist the screw back counter clockwise with the scissors.
    • Once the back is loose enough, you can use your fingers to twist it off.
  3. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: adım 3, 2 resimden 1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement, Time Setting Dial: adım 3, 2 resimden 2.
    • Press the release button for the Time Setting Dial using a thin pin.
  4. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: adım 4, 2 resimden 1. Fossil Speedway Watch TI-5061 Time Setting Dial Replacement: adım 4, 2 resimden 2.
    • Pull the dial out gently with fingers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Julia List
6.045 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,552
