Ana içeriğe geç
Framework Desktop Fastener Kit
Neye ihtiyacın var
  1. Framework Desktop Fastener Kit, Fastener information: adım 1, 2 resimden 1. Framework Desktop Fastener Kit, Fastener information: adım 1, 2 resimden 2.
    • The Fastener Kit contains the following:
    • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
    • Two large screws labeled "M6 ring screws"
    • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
    • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
    • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
    • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
    • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
    FixBot'a Sor
    Yorum Ekle
  2. Framework Desktop Fastener Kit, Top Panel screws: adım 2, 3 resimden 1. Framework Desktop Fastener Kit, Top Panel screws: adım 2, 3 resimden 2. Framework Desktop Fastener Kit, Top Panel screws: adım 2, 3 resimden 3.
    • The two screws labeled "M6 ring screws" secure the Top Panel.
    FixBot'a Sor
    Yorum Ekle
  3. Framework Desktop Fastener Kit, Fan screws: adım 3, 2 resimden 1. Framework Desktop Fastener Kit, Fan screws: adım 3, 2 resimden 2.
    • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
    FixBot'a Sor
    Yorum Ekle
  4. Framework Desktop Fastener Kit, Mainboard screws: adım 4, 2 resimden 1. Framework Desktop Fastener Kit, Mainboard screws: adım 4, 2 resimden 2.
    • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
    FixBot'a Sor
    Yorum Ekle
  5. Framework Desktop Fastener Kit, Power supply screws: adım 5, 2 resimden 1. Framework Desktop Fastener Kit, Power supply screws: adım 5, 2 resimden 2.
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
    FixBot'a Sor
    Yorum Ekle
  6. Framework Desktop Fastener Kit, Top plate screws: adım 6, 3 resimden 1. Framework Desktop Fastener Kit, Top plate screws: adım 6, 3 resimden 2. Framework Desktop Fastener Kit, Top plate screws: adım 6, 3 resimden 3.
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
    FixBot'a Sor
    Yorum Ekle
  7. Framework Desktop Fastener Kit, Rear plate screws: adım 7, 3 resimden 1. Framework Desktop Fastener Kit, Rear plate screws: adım 7, 3 resimden 2. Framework Desktop Fastener Kit, Rear plate screws: adım 7, 3 resimden 3.
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
    FixBot'a Sor
    Yorum Ekle
  8. Framework Desktop Fastener Kit, Side power supply screw: adım 8, 2 resimden 1. Framework Desktop Fastener Kit, Side power supply screw: adım 8, 2 resimden 2.
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
    FixBot'a Sor
    Yorum Ekle
  9. Framework Desktop Fastener Kit, Power duct screws: adım 9, 3 resimden 1. Framework Desktop Fastener Kit, Power duct screws: adım 9, 3 resimden 2. Framework Desktop Fastener Kit, Power duct screws: adım 9, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If you need help, contact Framework support.
Alex Diaz-Kokaisl
240.610 İtibar
1.180 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 255
