Ana içeriğe geç
Framework Desktop Heatsink Replacement
Neye ihtiyacın var
  1. Framework Desktop Heatsink Replacement, Power down your Desktop: adım 1, 3 resimden 1. Framework Desktop Heatsink Replacement, Power down your Desktop: adım 1, 3 resimden 2. Framework Desktop Heatsink Replacement, Power down your Desktop: adım 1, 3 resimden 3.
    • Before you begin repairs, shut down your desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
    • Make sure your Framework Desktop Screwdriver has the Phillips #2 bit (labeled as PH2) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Desktop Heatsink Replacement, Remove the Handle: adım 2, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the Handle: adım 2, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the Handle: adım 2, 3 resimden 3.
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop Heatsink Replacement, Remove the Top Panel screws: adım 3, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the Top Panel screws: adım 3, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the Top Panel screws: adım 3, 3 resimden 3.
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop Heatsink Replacement: adım 4, 3 resimden 1. Framework Desktop Heatsink Replacement: adım 4, 3 resimden 2. Framework Desktop Heatsink Replacement: adım 4, 3 resimden 3.
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop Heatsink Replacement: adım 5, 3 resimden 1. Framework Desktop Heatsink Replacement: adım 5, 3 resimden 2. Framework Desktop Heatsink Replacement: adım 5, 3 resimden 3.
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop Heatsink Replacement, Remove the Top Panel: adım 6, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the Top Panel: adım 6, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the Top Panel: adım 6, 3 resimden 3.
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop Heatsink Replacement, Remove the Left Panel: adım 7, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the Left Panel: adım 7, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the Left Panel: adım 7, 3 resimden 3.
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
  8. Framework Desktop Heatsink Replacement, Lay down the Desktop: adım 8, 2 resimden 1. Framework Desktop Heatsink Replacement, Lay down the Desktop: adım 8, 2 resimden 2.
    • Lay down the Desktop on its side so the fan is facing upward.
  9. Framework Desktop Heatsink Replacement, Disconnect the fan: adım 9, 2 resimden 1. Framework Desktop Heatsink Replacement, Disconnect the fan: adım 9, 2 resimden 2.
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
  10. Framework Desktop Heatsink Replacement: adım 10, 2 resimden 1. Framework Desktop Heatsink Replacement: adım 10, 2 resimden 2.
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
  11. Framework Desktop Heatsink Replacement, Remove the CPU fan screws: adım 11, 2 resimden 1. Framework Desktop Heatsink Replacement, Remove the CPU fan screws: adım 11, 2 resimden 2.
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
  12. Framework Desktop Heatsink Replacement, Remove the fan duct: adım 12, 2 resimden 1. Framework Desktop Heatsink Replacement, Remove the fan duct: adım 12, 2 resimden 2.
    • Lift the fan duct off the fan and remove it.
  13. Framework Desktop Heatsink Replacement, Remove the fan: adım 13, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the fan: adım 13, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the fan: adım 13, 3 resimden 3.
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
  14. Framework Desktop Heatsink Replacement, Loosen the heatsink screws: adım 14, 2 resimden 1. Framework Desktop Heatsink Replacement, Loosen the heatsink screws: adım 14, 2 resimden 2.
    • Use your Framework Desktop Screwdriver to loosen the final captive Phillips screw jutting out under the Primary Storage.
    • Use your Framework Desktop Screwdriver to loosen the four captive Phillips screws securing the heatsink in an "X" pattern starting with the top left screw.
    • Only loosen the screws a few turns at a time to avoid applying uneven pressure to the APU.
    • In order: top left → bottom right → bottom left → top right
  15. Framework Desktop Heatsink Replacement, Remove the heatsink: adım 15, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the heatsink: adım 15, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the heatsink: adım 15, 3 resimden 3.
    • Lift the heatsink and tilt it up towards the front of the Desktop to navigate it out of the chassis.
    • Remove the heatsink.
  16. Framework Desktop Heatsink Replacement, Thermal pad information: adım 16, 2 resimden 1. Framework Desktop Heatsink Replacement, Thermal pad information: adım 16, 2 resimden 2.
    • There are two types of thermal pads in the Desktop:
    • One thin, grey pad covering the back of the APU
    • Four thicker, blue pads covering the memory and power management
    • Upon removing the heatsink, the thicker pads will stick to either the bottom of the heatsink or to the Mainboard. Since replacement heatsinks come with pre-installed thermal pads, you just need to clean off the pads that remain on the Mainboard.
    • Follow the next two steps to remove the thermal pads remaining on the Mainboard.
  17. Framework Desktop Heatsink Replacement, Remove the thermal pads: adım 17, 2 resimden 1. Framework Desktop Heatsink Replacement, Remove the thermal pads: adım 17, 2 resimden 2.
    • Use your fingers to peel off the thermal pads from the memory and power management.
  18. Framework Desktop Heatsink Replacement, Clean the APU: adım 18, 2 resimden 1. Framework Desktop Heatsink Replacement, Clean the APU: adım 18, 2 resimden 2.
    • Apply a few drops of isopropyl alcohol (>90%) to the APU and use a coffee filter or a lint-free cloth to wipe away any residue.
  19. Framework Desktop Heatsink Replacement, Disassembly complete: adım 19, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  20. Framework Desktop Heatsink Replacement, Remove the liners: adım 20, 3 resimden 1. Framework Desktop Heatsink Replacement, Remove the liners: adım 20, 3 resimden 2. Framework Desktop Heatsink Replacement, Remove the liners: adım 20, 3 resimden 3.
    • Remove the liners covering the thermal pads on your replacement heatsink.
  21. Framework Desktop Heatsink Replacement, Place the heatsink: adım 21, 2 resimden 1. Framework Desktop Heatsink Replacement, Place the heatsink: adım 21, 2 resimden 2.
    • Tilt the heatsink down towards the rear of the Desktop and place it into its slot on the Mainboard.
  22. Framework Desktop Heatsink Replacement, Tighten the heatsink screws: adım 22, 2 resimden 1. Framework Desktop Heatsink Replacement, Tighten the heatsink screws: adım 22, 2 resimden 2.
    • Use your Framework Desktop Screwdriver to tighten the four captive Phillips screws securing the heatsink in an "X" pattern starting with the top right screw.
    • Only tighten the screws a few turns at a time to evenly compress the APU and thermal pads.
    • In order: top right → bottom left → bottom right → top left
    • Use your Framework Desktop Screwdriver to tighten the captive Phillips screw jutting out under the Primary Storage.
  23. Framework Desktop Heatsink Replacement, Insert the fan: adım 23, 3 resimden 1. Framework Desktop Heatsink Replacement, Insert the fan: adım 23, 3 resimden 2. Framework Desktop Heatsink Replacement, Insert the fan: adım 23, 3 resimden 3.
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
  24. Framework Desktop Heatsink Replacement: adım 24, 3 resimden 1. Framework Desktop Heatsink Replacement: adım 24, 3 resimden 2. Framework Desktop Heatsink Replacement: adım 24, 3 resimden 3.
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
  25. Framework Desktop Heatsink Replacement, Insert the fan duct: adım 25, 2 resimden 1. Framework Desktop Heatsink Replacement, Insert the fan duct: adım 25, 2 resimden 2.
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
  26. Framework Desktop Heatsink Replacement, Install the fan screws: adım 26, 2 resimden 1. Framework Desktop Heatsink Replacement, Install the fan screws: adım 26, 2 resimden 2.
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
  27. Framework Desktop Heatsink Replacement, Connect the fan: adım 27, 2 resimden 1. Framework Desktop Heatsink Replacement, Connect the fan: adım 27, 2 resimden 2.
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
  28. Framework Desktop Heatsink Replacement, Connect the RGB cable: adım 28, 3 resimden 1. Framework Desktop Heatsink Replacement, Connect the RGB cable: adım 28, 3 resimden 2. Framework Desktop Heatsink Replacement, Connect the RGB cable: adım 28, 3 resimden 3.
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
  29. Framework Desktop Heatsink Replacement, Install the Left Panel: adım 29, 3 resimden 1. Framework Desktop Heatsink Replacement, Install the Left Panel: adım 29, 3 resimden 2. Framework Desktop Heatsink Replacement, Install the Left Panel: adım 29, 3 resimden 3.
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  30. Framework Desktop Heatsink Replacement, Install the Top Panel: adım 30, 3 resimden 1. Framework Desktop Heatsink Replacement, Install the Top Panel: adım 30, 3 resimden 2. Framework Desktop Heatsink Replacement, Install the Top Panel: adım 30, 3 resimden 3.
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  31. Framework Desktop Heatsink Replacement: adım 31, 2 resimden 1. Framework Desktop Heatsink Replacement: adım 31, 2 resimden 2.
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  32. Framework Desktop Heatsink Replacement, Install the Handle: adım 32, 2 resimden 1. Framework Desktop Heatsink Replacement, Install the Handle: adım 32, 2 resimden 2.
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  33. Framework Desktop Heatsink Replacement, Install the top panel screws: adım 33, 3 resimden 1. Framework Desktop Heatsink Replacement, Install the top panel screws: adım 33, 3 resimden 2. Framework Desktop Heatsink Replacement, Install the top panel screws: adım 33, 3 resimden 3.
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  34. Framework Desktop Heatsink Replacement: adım 34, 3 resimden 1. Framework Desktop Heatsink Replacement: adım 34, 3 resimden 2. Framework Desktop Heatsink Replacement: adım 34, 3 resimden 3.
    • Repeat the same procedure for the other top panel screw.
  35. Framework Desktop Heatsink Replacement: adım 35, 3 resimden 1. Framework Desktop Heatsink Replacement: adım 35, 3 resimden 2. Framework Desktop Heatsink Replacement: adım 35, 3 resimden 3.
    • Use your finger to close the two D-rings on the top panel screws.
Sonuç
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
212.843 İtibar
1.039 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 67
Her zaman: 67
